little design from BesPav to work with higher q speakers - hoping dip will be up where won't matter
a lot
a lot
Freddi,little design from BesPav to work with higher q speakers - hoping dip will be up where won't matter
a lot
As you can see in the old 828G with one slanted horn wall compared to the 816A, it's parallel horn walls cause some dips around 600 & 1200 Hz with a bit of a rise in between.
BesPav's parallel horn walls are about 14" wide, the 828G throat 16", the 816A about 15", so you might expect BesPav's dips a little higher in frequency.
Art
