I just downloaded ABC dipole spreadsheet, but it seems some macroes do not work in my modern version of Excel 😀
I do not know if I can trust the model then.
Is there any alternative tool for calculating dipoles/open baffles?
Right know I would like to simulate the need for Xmax at a given low frequence. Lets say 30 Hz.
I would like to see the difference between a 6 mm Xmax 18" PA woofer, and a 25 mm Xmax 15" woofer. Both have low Qts and Fs around 30 Hz.
With ABC dipole it seems that the 15" woofer will actually perform better down to 30 Hz, but I don't know id i can trust the spreadsheet.
In H frame the 15" is about 105 dB SPL at 2 meter (listening position), and the 18" is only about 97 dB SPL
I can get more SPL with a U frame of similar size as the X frame at get 5 dB more SPL, but still the difference between 15" and 18" is still around 8 dB in favour of the long throw 15" woofer. Does it seem correct?
