You are going to add an attenuator to reduce the signal because you are going to use a step up transformer in the next stage which would otherwise cause overload??I want to keep the first 310A to keep the original circuit as possible, and add a attenuator between the pre and 91B
Please correct me if I am wrong.
Nice amp sir
Hi there Jerry, thanks for shareing, do you intend a WE type preamp to keep the synergy?, newbee question -but a modern/retro We system seems a great idear - how much like the origional would this sound like (another newbee question)- Would you need horns (Sato horns?) to finish the effect, I say this as i once heard a WE amp with horns and i never forgot the sound (road to Damascus experence)
Cheers Johnny
Cheers Johnny
Nice horns!
Hi Jerry,
Love those horns, I have been reading about the history of WE amplification ( inspired by your build somewhat) but the origin WE amp used for cinema amplification apparently (so I read) only went to 15 Khz, amp makers traffomatic claim the have a modern WE amps with none of the high frequency restrictions but to in house output transformers, is this embedded in your WE inspired approach?, assuming it is could you give any more info on the output transformers you used please.
Maney thanks and well done.
Regards Johnny
Hi Jerry,
Regards Johnny
- Tubes / Valves
- A WE-91B project
