A Very Simple MOSFET Amplifier
Here is a very simple MOSFET amplifier. I don't have the name for it. The output is similar to JLH output stage, but it can actually work in class B with MOSFET. Achieve good performance with relatively small number of parts. It also has the capability of almost rail to rail voltage swing, which is the weak point of most other MOSFET designs.
[EDIT] Added constant current source for the bias. Thus, the power rail fluctuation will not affect the bias.
[EDIT] Add the protection.
R5 is the pot for the bias. Currently at 184ma
10KHz 20Vp into 8 Ohm.
looks very simple to me good job
Nice to see the bootstrap to get the voltage swing for the MOSFETs. How about idle current stability with temperature, have you simulated?
Here the bias Vgs is proportional to the supply voltage. If the power supply is not regulated, the bias should be stable.
In the case of regulated power supply, I suggest to add an extra pair of 0.22 sensing resistors to the source of mosfet.
In general, mosfet internal resistance rises along with the temperature. You can get away without source resistors.
I would disagree, quite strongly. Below please see my take on the Blameless with EF2 an 2 pairs of output devices. THD vs, frequency at 150W/4ohm. It is not a toy, and it is the real thing measurement.
You are right. My memory must have been fogged.
Just a quick spin for the blameless design, for reference. Same bias, same unit loop gain bandwidth. The blameless is -10, to -15dB better THD @10K.
Loop gain. As the output stage is included in the Miller compensation loop, don't worry about astronomical unit loop gain bandwidth. As you can see, even though, it is stable.
Nice. Now it would be good to build a sample. That’s why we do it. Excuse me, I am a 70 years old old school guy, and the goal of this hobby for us was to build the amplifiers. Simulators do not make the speakers to sound, yet 😉. Yes they are an effective tool, but just the first step.
The distortion coming from the average MOSFET is hilarious high. Even bias it into class A, the THD number doesn't even budge -3dB. For class A, the JLH style BJT output stage might be better.
It might be the problem with my simulation software. However, the simulation of the Blameless topology is pretty accurate.
Maybe I should try the new Lateral type MOSFET.
Reactions: PMA
It is good to use error correction to reduce distortion of MOSFETs with high Vgs.
