A very Clean and great sounding 12V Battery Powered Mini Boombox
This is my on-going project.
A portable Battery operated mini Boombox using TA8210, a BTL amp made by Toshiba.
I am very pleasantly surprised with its sound quality. I tested the amp with big full range speakers too and it sounded great there too. Very nice , clean, detailed and rich sound.
I followed the PCB layout from construyasuvideorockola.com
Read more here: http://construyasuvideorockola.com/proyect_amp_40w.php
The power amplifier PCB Layout was correct but the 3 band equaliser circuit has a problem. I fixed that using a pair of 1uf non polar cap between the Op-amp output and volume control. However, this equaliser operates with 12 volt too and a perfect companion for any BoomBox.
Read more:http://construyasuvideorockola.com/proyect_pre_eq_simple.php
If any member of construyasuvideorockola.com is reading my post here, please fix your circuits. I found at least 3 problems in your hard works in various projects that I had attempted earlier and some of your crucial and very basic mistakes were solved with the help of kind and experienced diyaudio members and a moderator here. This can be seriously frustrating to a newcomer who wants to attempt your projects. I don't know Spanish otherwise I would have informed you about the mistakes found in your circuits.
But you are doing a great and praiseworthy job.
So a big thank you, construyasuvideorockola.com.
The huge LED spectrum analyser was made with the reference from podsviceni.com. So I thank them too.
I salvaged the speakers from an old out of order TV set.
I just attached the tiny speakers to a front panel made with a 6mm plywood plank. I am testing the sound of the open-baffle design. :p Not bad.
I sincerely value your experienced words/ suggestion to make this project a better one.
Thank you. :)
Sir, I am new here. Your project inspired me..
Welcome to the forum and wish you a very happy journey here along with us.
Thank you for your comment.
I tried the link which you posted above for amp and pre-amp, but there are only photos of ready built pcbs. So kindly please post the layout of preamp and power amp here or you can mail me sir. Thank s in advance.
To get the project files of the spectrum analyser,
1. download the rar files from the description of the video of zarovka29
"10 band audio spectrum analyzer with 400 LED FullHD "
10 band audio spectrum analyzer with 400 LED FullHD - YouTube
and the direct download link is there below
http://podsviceni.com/spectrum_analyzer.rar
2. Use any unzipping software you like. I use 7zip it is a free software.
3. Once unzipped you can open the .sch ( the schematic file) and .pcb file ( the pcb layout design) with the free and light version of Cadsoft Eagle)
___________________________________
To get the Boombox files:
Go to www.construyasuvideorockola.com and download the pdf files.
You can use google translator to translate the page.
Amplificador de 40w con ta8210
and the direct download of the pdf files:
http://construyasuvideorockola.com/downloads/ta8210_flat.pdf
Then just use the toner transfer method.
Hope this helps.
All the best for your project. :)
