I am using the cheap-o Hammond 125SE transformers. and I look at the schematic an I see that I need a center-tap to run to the grid. looking at the transformer digram, there is no center tap!!! what do I do?
What grid, G2? What are you trying to do make a ultra linear with a SE output xfmer that has no primary tap?
In the case of a xfmer used to drive and also act as phase splitter for push pull grids it is possible to create a phantom CT by using a center tapped resistance between the two ends of the transformer secondary. It is not ideal and you lose voltage swing. Good "desert island" trick though.
yeah, pretty much. Is there anything i can do?
Get a sewing needle and insulate it competely except for the very tip. Connect G2 to it with a piece of wire. Poke the needle into the primary winding and hope you get lucky. 😀
I'm mostly kidding. Don't do this.
haha, sounds like a good idea!!!!
What I am going to do is connect the tubes in a Triode configuration untill i order some cheap transformers with center taps, which leads me to another question.
I need a primary resistance of 2.5k and a secondary of 8 (both are ohms)
The Hammond 125SE shows the following diagram
This has a universial primary winding (from 2.5k, to 10k) so assume I wanted 2.5K primary, and 8 secondary, then I would use the white connection, however If i had a 5k primary the same tap would be the 16 ohm connection.
look at the edcor equvilent with a middle tap, and no universal primary
This model has a fixed primary at 5k ohms, and a fixed secondary at 16 ohms, now, after all this explination my question!
could I use this fixed 5k, 16 ohm transformer with a primary of 2.5k, and a secondary of 8?
Yes, you could use the Edcor that way but if a 2.5K to 8 ohm Edcor is available, buy that instead.
FYI, the screen tap on an UL xfmer is not set at 50%. It is most often 40% from the B+ end. On some xfmers it is less than 40%.
Yes you can. I used the Edcor XSE-15-8-5K (8 ohm model) with a 4 ohm load to get a 2500 ohm primary. It worked quite well. I am now using these transformers with UL in a 6L6 amp. These transformers sound far better than $18 transformers should.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=72654&highlight=
The experiment was in post #43 and 44
I have the amp working, but am still tweaking on it. As soon as I have the details worked out I will post the schematic on my web site. I will also put it in the previously mentioned Cheap SE output transformers thread. Given my current work load it might be a week or two.
I am currently running a 5K load for all of the experiments that I am doing. The amp sounds fantastic. I may try 2.5K to see if there is much degradation in sound quality.
- Tubes / Valves
- A Transformer question
