A problem but not DIY My amp just died
diyAudio Member
Joined 2007
I build speakers not amps so please be kind.
One of my Kenwood L-07M monoblocks just died.
I bought them used and I've had them for about 20 years so I guess I can't complain.
They are [ or were] driving the tops in my Tri-amped home system.
Should I try and get a repair done of just buy a new stereo amp of similar specifications?
Any and all suggestions welcome but my budget is severely limited at the moment.
I've owned lots of amplifiers over the years but the old Kenwoods were the best sounding amps I have ever owned
Definitely worth getting them fixed, all the documentation for these is on Hi Fi Engine. You just need to find a good audio repair guy in Melbourne.
A new amp of similar specs will be hard to find and it definitely won't be as well built. Might only cost a couple of hundred to fix, especially if the other one is working for comparison checks.
Reactions: MarkC568
You are in a good position, as you have a working sample. Download the service manual, print out the sides of the schematics and combine them to a large readable one. Repair guys are lazy, some don't even start without a well readable schematic.
With a working sample for reverence and a clear schematic, such a repair should be quite easy. That does not mean cheap.
Maybe use the time to fix them and try something new, like a small D-amp. I recently got an AYIMA A07 (the basic version) for 45$US. Pair it with some power supply you have flyin around and just be surprised... I know, old dogs don't like to learn new tricks, but these sound very nice, really.
When I bought these the seller did provide such, thanx for mentioning it and I'll try and find them. I do have a cheap chip-amp kit here; two sets of the Jaycar amp; maybe I should actually try and build a couple of small units but the speakers do need a bit of oomph to really sing and I'm not sure 50 watts is enough.
