A Preamp doesn't work well!! (distortion)
I just made a preamp (Gain : 4.3, non-inverting, opamp : opa2604), and there is a problem..
I thought X4.3 is not a big deal because the guitar signal is not that large, but there was distortion when using rear humbucker.
Does anyone know the reason?
Agree.
If you have only a 9V battery available a hot humbucker might overdrive that preamp, specially because most Op Amps do not reach the rails (in this case +)v and ground) but stop a couple volts earlier, which severely limits headroom.
Often you can´t go beyond 2X gain. 🙁
