A New Take on the Classic Pass Labs D1 with an ESS Dac
1. cersepn x 1
2. icewall x 2
3. pmchoong x 1
4. qusp x 1 this is tentative mate, but wanted to make sure my name was down
5. regal
6. randytsuch x 1
7. LK x1
8. greyrab x1
9. alexcount x1
10. adelias x1
11. Coolhead x1 + fets
12. Emphrygian x 1
13. tranhieu x 1
14. crazyfrog x 1
15. woresseo x 2
16. Algar_emi x 1
17. ggetzoff x 1
18. syklab x1 + fets
19. Magsy x 1
20. Vitalica x2 + fets
21. Pinnocchio x 2
22. hochopeper x 1
23. neb001 x1 + fets
24. bigpandahk x 2 + fets
25, Jean-Charles X1 +fets
26,iancanada X1 + fets
27. lll X1+fets
28. analog_sa x2 + fets x 2 (shipping to US)
29. savvas + fets
30. lm1no2 x1 + fets
31. trickymicky X 1 + fets
32. Regland x 2
33. flocchini x1
34. hirez69 x2 + fets x 2 (for BIII)
35. Reenberg x 1 + fets
36. ed linssen X1+fets (for BIII)
37. tehrkn x 1 + fets
38. slartibartfasst x1
39. misterrogers x 1 + fets (for BIII)
40. lwif x 1 + fets (for BIII) (I know fets are not available, let's that as a wish)
41. Horio x 1
42 . CeeVee x1 for BIII
43. Eternalightwithin x2 + fets for BIII. (Waiting list)? ;-(
44. atom6422 x 1 + fets
Hi Guys,
The board has been updated, and I'm ready to send it in for fabrication.
I managed to find a layout that will accommodate the Acko, the BII and the BIII. I have attached the updated layout for people to take a look at.
If someone owns a BIII and a printer, I would really appreciate it if they could print off the attached layout, and lay the BIII over top to see if everything lines up and fits. It's should be to scale if printed on a piece of 8.5 x 11 paper.
The only thing left to do is add the digital input connectors (if they fit) for the BIII so that both the BIII and BII can use the digital input section if people want. Can someone provide me with the location and pinout for this connector? (this is mostly a request for bigpandahk)
Also note that the RCA connector has been replaced with a BNC, and the jumpers have been replaced by a switch for switching between AES/EBU and SPDIF.
Any comments are welcome, and I'm still open to any suggestions people might have for improvements. I'd like to send this off for fab in a few days, so please let me know if anyone sees any issues.
Owen
Everything are perfect. You use output header 1 & 2 instead of 3 & 4 default for the ivy.
I've already indicated the digital input connector on the drawing. It's at the top of the PCB, a 2x10 pins 0.1" pitch DIN, from left to right are : DCK, D1, D2, D3, D4, D5, D6, D7, D8, VD. Below are extract from integration guide:
Connecting sources directly to the DAC board
Although many will prefer to use input modules like the S/PDIF-4 Input Board and Sidecar, it is possible to connect digital sources directly to the Bufallo III DAC board.
TTL level S/PDIF
For TTL level S/PDIF the following connections are possible, stereo only:
Connection
DIN (DIN, 1)
S/PDIF input 1 D1, GND
S/PDIF input 2 D2, GND
S/PDIF input 3 D3, GND
S/PDIF input 4 D4, GND
S/PDIF input 5 D5, GND
S/PDIF input 6 D6, GND
S/PDIF input 7 D7, GND
S/PDIF input 8 D8, GND
TTL level PCM
The Bufallo III DAC board also supports TTL level PCM (I2S by default), which can be multi-channel:
GRN-------------------GRN
Bit clock-------------- DCK
Word clock(LRCK)------D1
Data-------------------- D2----Channels---1 and 2
--------------------------D3------------------3 and 4
--------------------------D4------------------5 and 6
--------------------------D5------------------7 and 8
1. cersepn x 1
2. icewall x 2
3. pmchoong x 1
5. regal
6. randytsuch x 1
7. LK x1
8. greyrab x1
9. alexcount x1
10. adelias x1
12. Emphrygian x 1
13. tranhieu x 1
14. crazyfrog x 1
15. woresseo x 2
16. Algar_emi x 1
17. ggetzoff x 1
19. Magsy x 1
21. Pinnocchio x 2
22. hochopeper x 1
27. lll X1+fets
29. savvas + fets
32. Regland x 2
33. flocchini x1
41. Horio x 1
45. blitz x2 for BIII and fets if avail...
thanks a lot !!!
1. cersepn x 1
2. icewall x 2
3. pmchoong x 1
5. regal
6. randytsuch x 1
7. LK x1
8. greyrab x1
9. alexcount x1
10. adelias x1
12. Emphrygian x 1
13. tranhieu x 1
14. crazyfrog x 1
15. woresseo x 2
16. Algar_emi x 1
17. ggetzoff x 1
19. Magsy x 1
21. Pinnocchio x 2
22. hochopeper x 1
27. lll X1+fets
29. savvas + fets
32. Regland x 2
33. flocchini x1
41. Horio x 1
46. BDL x 1
Hi Guys,
any chance of actually putting a score mark to snap off the PSU this time mate? i'll still use it most likely, just as I am with the first one, but its more flexible for mounting ackodac if separate as the heatsinks from the psu get in the way of the regulator mounting arrangments
1. cersepn x 1
2. icewall x 2
3. pmchoong x 1
5. regal
6. randytsuch x 1
7. LK x1
8. greyrab x1
9. alexcount x1
10. adelias x1
12. Emphrygian x 1
13. tranhieu x 1
14. crazyfrog x 1
15. woresseo x 2
16. Algar_emi x 1
17. ggetzoff x 1
19. Magsy x 1
21. Pinnocchio x 2
22. hochopeper x 1
27. lll X1+fets
29. savvas + fets
32. Regland x 2
33. flocchini x1
41. Horio x 1
46. BDL x 1
47. outriding x2 (PCB) + x1 FETs if available
1. cersepn x 1
2. icewall x 2
3. pmchoong x 1
5. regal
6. randytsuch x 1
7. LK x1
8. greyrab x1
9. alexcount x1
10. adelias x1
12. Emphrygian x 1
13. tranhieu x 1
14. crazyfrog x 1
15. woresseo x 2
16. Algar_emi x 1
17. ggetzoff x 1
19. Magsy x 1
21. Pinnocchio x 2
22. hochopeper x 1
27. lll X1+fets
29. savvas + fets
32. Regland x 2
33. flocchini x1
39. misterrogers x 2 + fets (for BIII)
41. Horio x 1
46. BDL x 1
I know I'd regret not getting a second set - upped my count.
1. cersepn x 1
2. icewall x 2
3. pmchoong x 1
5. regal
6. randytsuch x 1
7. LK x1
8. greyrab x1
9. alexcount x1
10. adelias x1
12. Emphrygian x 1
13. tranhieu x 1
14. crazyfrog x 1
15. woresseo x 2
16. Algar_emi x 1
17. ggetzoff x 1
19. Magsy x 1
21. Pinnocchio x 2
22. hochopeper x 1
27. lll X1+fets
29. savvas + fets
32. Regland x 2
33. flocchini x1
41. Horio x 1
46. BDL x 1
48. yoke x 3 + 3 x fets
1. cersepn x 1
2. icewall x 2
3. pmchoong x 1
5. regal
6. randytsuch x 1
7. LK x1
8. greyrab x1
9. alexcount x1
10. adelias x1
12. Emphrygian x 1
13. tranhieu x 1
14. crazyfrog x 1
15. woresseo x 2
16. Algar_emi x 1
17. ggetzoff x 1
19. Magsy x 1
21. Pinnocchio x 2
22. hochopeper x 1
27. lll X1+fets
29. savvas + fets
32. Regland x 2
33. flocchini x1
41. Horio x 1
46. BDL x 1
49. meintan X1 +fets (for BIII)
Hi. I have problem with my D1. I removed the PCB assembly to work on the case, and after I put it back I got noise (hiss, buzz, and fluctuation pulse in the audio, very disturbing).
I checked all the supplied and the DC voltage adjustment for the ESS DAC (Version 1), still ok at 1.6V after stabilization.
Any idea what can be the problem? Is my DAC PCB defective?
Thanks...
SB
1. cersepn x 1
2. icewall x 2
3. pmchoong x 1
5. regal
6. randytsuch x 1
7. LK x1
8. greyrab x1
9. alexcount x1
10. adelias x1
12. Emphrygian x 1
13. tranhieu x 1
14. crazyfrog x 1
15. woresseo x 2
16. Algar_emi x 1
17. ggetzoff x 1
19. Magsy x 1
21. Pinnocchio x 2
22. hochopeper x 1
27. lll X1+fets
29. savvas + fets
32. Regland x 2
33. flocchini x1
41. Horio x 1
46. BDL x 1
50. necplusultra x 2 + fets (for BIII)
1. cersepn x 1
2. icewall x 2
3. pmchoong x 1
5. regalx1
6. randytsuch x 1
7. LK x1
8. greyrab x1
9. alexcount x1
10. adelias x1
12. Emphrygian x 1
13. tranhieu x 1
14. crazyfrog x 1
15. woresseo x 2
16. Algar_emi x 1
17. ggetzoff x 1
19. Magsy x 1
21. Pinnocchio x 2
22. hochopeper x 1
27. lll X1+fets
29. savvas + fets
32. Regland x 2
33. flocchini x1
41. Horio x 1
46. BDL x 1
1. cersepn x 1
2. icewall x 2
3. pmchoong x 1
5. regalx1
6. randytsuch x 1
7. LK x1
8. greyrab x1
9. alexcount x1
10. adelias x1
12. Emphrygian x 1
13. tranhieu x 1
14. crazyfrog x 1
15. woresseo x 2
16. Algar_emi x 1
17. ggetzoff x 1
19. Magsy x 1
21. Pinnocchio x 2
22. hochopeper x 1
27. lll X1+fets
29. savvas + fets
32. Regland x 2
33. flocchini x1
41. Horio x 1
46. BDL x 1
51. johnwmclean x 2 + fets (for BIII)
