I need a confirmation about the rule that I learned in College too long ago.
When 2 capacitors of 25 uf - 100v are in a parrallel circuit the total capacitance for this circuit will be 12.5 uf at a mximum voltage of 100volts ?
When 2 capacitors of 25 uf - 100v are in a series circuit the total capacitance for this circuit will be 25 uf but maximum voltage of 200volts ?
Theses rules apply to Non-Polarized capacitors also ?
Please refresh my memory, thanks.
Capacitors in parallel sum. 2x25 = 50 uF, 100v in your case
capacitors in series Csum=1/(1/C1 + 1/C2) voltage the sum of the voltages of the caps (12.5 uF, 200V in your case).
dave
dave
dave
I'll give the 200 Volt rating a big maybe. Capacitors in series may not divide the voltages evenly. Often a high value resistor is connected across each cap. to help with the voltage division.
Always recommended.
dave
When you say high value resistor what kind of value (in ohms) are we talking about ?
Also how many watt resistor do you recommend, 1/4 w, 1/8 w, 1/2 w, 1 watt, 2 watts ?
I don't remember!
Probably someone in the "Tubes / Valves" sub-forum would know.
Ripple current and ESR
Hope this is not off topic.
What happens to ripple current and ESR when you parallel / series?
- A little refresher please - Capacitors in parallel
