Hi formula 22
I have a circuit from elektor with PCC88 as voltage amplifier and 2SK176/2SJ56 as current amplifier, you can use IRFP240/IRFP9240 without problem, the article is in PDF format, but is too big (1.35MB) for the forum, send to me a private message and I will send to you the complete article.
Best regards
Johann
Best regards
Johann
Hi Johann ,Hi formula 22
Best regards
Johann
May I have this one too ?
My e-mail : email address removed. send a pm
Many thanks
Circuit from Elektor with PCC88
Hi Mr Johann!
Here is my e-mail address: petrusarmagedon@yahoo.com, to which you can submit a project Hybrid amplifier with PCC88 in pdf format (from Elektor).
thank you!
Hi formula 22
Best regards
Johann
Hi Mr Johann!
thank you!
Hi Johann,
I would read this paper, too.
My email address is booryon@yahoo.com, please.
Thank you very much,
Ion
Hi Johann,
Ion
Hello,
I need it too...If it's possible.
My e-mail is boris.kovacevic@zg.t-com.hr
Thank you in advance, regards,
Boris
Hello,
Boris
Schematic
Dear Mr,
I need schematic to. Can you please send it to my e-mail:
Thank you, regards,
Boris
Dear Mr,
Thank you, regards,
Boris
Hi Johann!Hi formula22
I sent the article on march 06, I sent again today. Your e-mail adress is correct?
Let me know if you receive the e-mail.
Best regards
Johann
I got a project with PCC88 (from Elektor) and here is very good audio amplifier in the A-class, and I need the AB-class with power supply Ucc=+/-38Vdc.
thank you and cheers!
Hi formula 22
The elektor amp. is AB-class, if you read the article, you can down the power supply voltage from +/- 42V to +/- 30V, so you can use at +/- 38V.
(Is impossible to obtain almost 100W in class A with MOSFETs used by elektor, you must use at least 8N and 8P)
You can also use IRFP240/IRFP9240 without problem.
I think the circuit can cover your expectancy.
Best regards
Johann
Best regards
Johann
Hi popilin!Hi formula 22
Best regards
Johann
Please refer to technical characteristics.
thank you
Schematic
Dear all,
Perhaps I'm lost in all corespondence, so please help me with schematic if it's possible.
I need this schematic and I'm kindly asking you to send me on my e-mail:
Thank you all in advance, best regards,
Boris
Dear all,
Boris
Measurements for this hybrid amplifiers.
Thank you for your cooperation Johann.
Did you made this amplifier, if you made any sound gives?
If you have some measurements with harmonics views give them here.
Thanks and cheers!
Hi formula 22
Technical characteristics are wrong, with +/-42V you can obtain almost 100W.
I think the author want to say 2 x 65W.
Read the article, please.
Best regards
Johann
Thanks and cheers!
- Tubes / Valves
- A hybrid amplifier with PCC88 and IRFP240/9240
