A fried Krell-any help?
Hi guys
I m trying to find the schematic/design of the Krell KSA100S power amp because the Krell dealer (not an official distributor actually)in my country doesn’t give it to me.My Krell’s one channel was fried 🙁 ,I have no idea why and I want to fix it myself. Anyone can help?
This may help.
mecanp....inject a signal into the left channel EX. 1KHz sine wave and with your meter follow the signal and see where there is no output...........you can also test the transistors for shorts starting at the power transistors then down to the driver transistors
Cheers!!The DIRT®
If i was you...
I would send it to Krell USA for repair.
You`re gonna mess things up for sure,if you try to repair it yourself.
The KSA100 is not the same design as the KSA100s,And the schematic is nowhere to be found.
