A excellent Pre-amp
I'm no expert on subs and the actual acoustics of them.
120hz sounds about right but I imagine depends on the design of the sub enclosure and its response. And the main speakers too of course.
I wouldn't think you need filter anything below 10 or 20 hz unless you play vinyl which would cause massive rumble.
You can attenuate the low frequency response a bit if you reduce the value of C2 on the input of your power amplifier.
Other than that, you could add a couple of Opamp stages to your Low Pass Filter and attenuate the audio below the low frequency limit of your sub.
thanks a lot Mooly & Frank for your all advices. really helped me
Frank what did you mean by this??? :
This circuit shouldn't produce any additional hum. It will amplify any hum that is present on the input.
It may be a problem with the layout or a grounding issue. You may also need better filtering of the power supply outputs.
