I just received
Câbles en kit - AUDIOPHONICS XP-OCC Kit Câble de Modulation RCA Cuivre OCC 1m
and I see now there is no magnetic shield in this kit! What do you think of that? 😕
I just received
Well, unless you speak (read) French....
It seems to be a single conductor 24AWG copper wire with impossible-to-work with teflon insulation. Useful for some hi-temp industrial application.
Other than that?
E
Other than that?
E
The English term for this cable is an "rca interconnect cable." I do speak French, but (very) badly after 3 decades of disuse.
Not sure where mickeymoose got the impression the OFC wire is insulated with teflon - it states specifically that it is uninsulated. This is a kit with teflon sleeving, natural cotton tubing, and rca plugs.
Not sure how much merit these interconnects have, they certainly will not tolerate a great deal of flexing.
Si le kit n'est pas trop cher peut etre amusant a realize soi-meme.. Le resultat, cette une autre chose..
FWIW, there is no magnetic shield in any interconnect. Many do have an electro-static shield, aka shield - the good ones use a mesh providing a high % of shielding, the cheap ones use a spiral of untwisted stranded conductors which is not very effective IMHO. I use lots of interconnects without shielding in my system and as long as the source impedance is low generally I have not had any problems. This design should have relatively low capacitance by virtue of the teflon dielectric (tubing) and for some resistance to EMI a very mild twist could be helpful, but not necessarily what the kit designer had in mind. (Mine are mostly not twisted)
