A DIY Beginner's Journey
@6sX7 The cheap gun type like the Vcelink on amazon work just fine and are good up to 24ga.
You probably saw something like the old school jaw type Kleins. A little more money, good up to 22ga and much more substantial. I use tools professionally, swear by Klein generally but carry the cheap Vcelinks in this case.
Reactions: 6sX7
I have the Klein mentioned above and an old, really old one like, this. Can't say I use either in favor of 2 different manual strippers, 1 up to 26 gauge, the other a craftsman version of a Klein(?) for the majority.
Matter of fact if you want the Klein pm me.
Reactions: 6sX7
Reactions: Toys4Boys
Long ago, while on a factory tour at Mark Levinson, I was told they use mechanical, crimp, connections first and seal the joint with solder. After researching a bit, the choice of crimp or solder largely comes down to the skill of the builder. It is not clear that "sealing " the joint with solder has advantages that outweigh the downside, largely that it makes the joint more brittle. That being said, here is a link to a chart by NASA.
A properly done crimp connection forms a cold weld that is gas tight.
It is difficult to make a proper crimp, therefore solder is a reasonable means of ensuring a strong and stable connection. The crimp forms the mechanical bond and solder keeps it gas tight.
Making a good solder joint also requires knowledge and practice. No free lunch.
Reactions: Toadroller
Looking back at my first builds, not from here 😞, I realize that my first kits were a bit advanced for my skills at the time. With the benefit of having completed a few kits, still need to troubleshoot the first 2, I would suggest that anyone getting started should consider something like the ACA Mini. These are pretty quick, instant gratification 😉, simple to build, Cheap and have the best support. As a second project the A Jzm is a great option, not only will it help develop one's skills, it's a nice step up from the ACA Mini, also you have the benefit of @ItsAllInMyHead's excellent build guide.
I recall Dynaco kits, and later the Audio by Van Alstein kits, were paint by number. They told you how long to cut wire, and how much insulation to strip away on the tips even! Pics as you went along, etc. I never bought any of the Heath Kit stuff....
Russellc
FWIW, while Klein has been the undisputed king of hand tools in the N. American electrical trades for decades, Knipex is rapidly gaining ground. They're the first real contender in the field since I started in the early 80's. I plan on trying their gear but you can have my klein 8" d2000 diagonals when you pry them from my cold, dead hands.
What's next? A serious challenger to Fluke? (I do love my Brymen 869 😉 )
Got the $50 Knipex stripper. Very nice. Adjustable tension on the jaws. Adjustable strip length. Very easy lever pull. Makes a nice clean cut. Don't know why I didn't get one sooner. X-acto knife is so tedious.
