Trying to figure out exactly what to do with my pair of B&C 18SW115 drivers. I came up with this tonight. Here is my rough Akabak script. The whole thing should fit in a 48x48x22.5
Opinions?
Def_Const
S1 = 208.00e-4;
S2 = 835.00e-4;
S3 = 2410.00e-4;
S4 = 2748.00e-4;
S5 = 4495.72e-4;
L12 = 23.00e-2;
L23 = 312.60e-2;
L34 = 46.00e-2;
L45 = 63.40e-2;
Vtc = 15746.00e-6;
Atc = 2420.00e-4;
Sd = 2420.00e-4; |Total diaphragm area for 2 parallel drivers (sq m)
Ltc = Vtc / Atc;
Def_Driver 'Driver'
Sd=1210.00cm2
Bl=30.32Tm
Cms=8.96E-05m/N
Rms=9.91Ns/m
fs=32.0003Hz
Le=1.90mH
Re=5.30ohm
ExpoLe=1
System 'System'
Driver Def='Driver''Driver 11'
Node=1=0=5=11
Driver Def='Driver''Driver 21'
Node=1=0=5=11
Filter 'HP1' |24dB Butterworth High pass filter
fo=23Hz vo=1
{b4=1;
a4=1; a3=2.613126; a2=3.414214; a1=2.613126; a0=1; }
Filter 'LP1' |48dB LR Low pass filter
fo=90Hz vo=1
{b0=1;
a8=1; a7=5.226252; a6=13.656854; a5=23.069792; a4=27.313708; a3=23.069792; a2=13.656854; a1=5.226252; a0=1; }
Duct 'Throat chamber'
Node=5=9
SD={Atc}
Len={Ltc}
Visc=0
Waveguide 'Horn segment 1'
Node=8=9
STh={S1}
SMo={S2}
Len={L12}
Conical
Waveguide 'Horn segment 2'
Node=9=10
STh={S2}
SMo={S3}
Len={L23}
Conical
Waveguide 'Horn segment 3'
Node=10=11
STh={S3}
SMo={S4}
Len={L34}
Conical
Waveguide 'Horn segment 4'
Node=11=12
STh={S4}
SMo={S5}
Len={L45}
Conical
Radiator 'Horn mouth'
Node=12
SD={S5}
Opinions?
Def_Const
S1 = 208.00e-4;
S2 = 835.00e-4;
S3 = 2410.00e-4;
S4 = 2748.00e-4;
S5 = 4495.72e-4;
L12 = 23.00e-2;
L23 = 312.60e-2;
L34 = 46.00e-2;
L45 = 63.40e-2;
Vtc = 15746.00e-6;
Atc = 2420.00e-4;
Ltc = Vtc / Atc;
Def_Driver 'Driver'
Sd=1210.00cm2
Bl=30.32Tm
Cms=8.96E-05m/N
Rms=9.91Ns/m
fs=32.0003Hz
Le=1.90mH
Re=5.30ohm
ExpoLe=1
System 'System'
Node=1=0=5=11
Node=1=0=5=11
fo=23Hz vo=1
{b4=1;
fo=90Hz vo=1
{b0=1;
Node=5=9
SD={Atc}
Len={Ltc}
Visc=0
Node=8=9
STh={S1}
SMo={S2}
Len={L12}
Conical
Node=9=10
STh={S2}
SMo={S3}
Len={L23}
Conical
Node=10=11
STh={S3}
SMo={S4}
Len={L34}
Conical
Node=11=12
STh={S4}
SMo={S5}
Len={L45}
Conical
Node=12
SD={S5}
Okay, this is my first crack at interpreting Akabakese!
is this a parallel dual driver back loaded horn?
the bandpass filter, is it an electronic one?
if im even close yay, if not tell me where i missed the port.
this might just wail and scare some people.
im conceptualizing on using a horn basd sub in a car to turn heads to a really loud single driver solution for hatchbacks.
looking forward to seeing drawings and real wood.
Yes it is a TH. The filter are sims of active filters that would be in place. I'm working on/finishing the layout in Sketchup today.
w/o filters
w/o filters
Nice response, flat in room to 20hz. Is it for a theater?
Also, are both drivers going in one enclosure? Oops yeah i see that now.
I'll probably use it for live sound and outdoor movie nights. I'm building something else for home theater using a MTX T9515-04 (just arrived Thursday 😀 )
The design is still a little rough but this is what I drew up today. It came out a little bigger at 52x52x22.5
Def_Const
S1 = 0.50e-4;
S2 = 477.84e-4;
S3 = 358.38e-4;
S4 = 901.38e-4;
S5 = 1205.46e-4;
S6 = 1813.62e-4;
S7 = 2280.60e-4;
S8 = 2519.52e-4;
S9 = 3105.96e-4;
S10 = 3659.82e-4;
S11 = 4496.04e-4;
L12 = 8.60e-2;
L23 = 21.90e-2;
L34 = 22.30e-2;
L45 = 130.10e-2;
L56 = 57.30e-2;
L67 = 142.30e-2;
L78 = 48.30e-2;
L89 = 25.80e-2;
L910 = 21.60e-2;
L1011 = 5.50e-2;
Vtc = 15746.00e-6;
Atc = 1210.00e-4;
Ltc = Vtc / Atc;
Def_Driver 'Driver'
Sd=1210.00cm2
Bl=30.32Tm
Cms=8.96E-05m/N
Rms=9.91Ns/m
fs=32.0003Hz
Le=1.90mH
Re=5.30ohm
ExpoLe=1
System 'System'
Node=1=0=5=16
Node=1=0=5=16
Filter 'HP1'
fo=22Hz vo=1
{b4=1;
Filter 'LP1'
fo=83Hz vo=1
{b0=1;
Duct 'Throat chamber '
Node=5=10
SD={Atc}
Len={Ltc}
Visc=0
Node=8=9
STh={S1}
SMo={S2}
Len={L12}
Conical
Duct 'Horn segment 2'
Node=9=10
HD=54.3cm WD=8.8cm Len=21.9cm
Duct 'Horn segment 3' |*
Node=10=11
HD=54.3cm WD=6.6cm Len=22.3cm
Node=11=12
STh={S4}
SMo={S5}
Len={L45}
Conical
Waveguide 'Horn segment 5'
Node=12=13
STh={S5}
SMo={S6}
Len={L56}
Conical
Waveguide 'Horn segment 6'
Node=13=14
STh={S6}
SMo={S7}
Len={L67}
Conical
Waveguide 'Horn segment 7'
Node=14=15
STh={S7}
SMo={S8}
Len={L78}
Conical
Waveguide 'Horn segment 8'
Node=15=16
STh={S8}
SMo={S9}
Len={L89}
Conical
Waveguide 'Horn segment 9' |*
Node=16=17
STh={S9}
SMo={S10}
Len={L910}
Conical
Waveguide 'Horn segment 10'
Node=17=18
STh={S10}
SMo={S11}
Len={L1011}
Conical
Node=18
SD={S11}
Def_Const
S1 = 0.50e-4;
S2 = 477.84e-4;
S3 = 358.38e-4;
S4 = 901.38e-4;
S5 = 1205.46e-4;
S6 = 1813.62e-4;
S7 = 2280.60e-4;
S8 = 2519.52e-4;
S9 = 3105.96e-4;
S10 = 3659.82e-4;
S11 = 4496.04e-4;
L12 = 8.60e-2;
L23 = 21.90e-2;
L34 = 22.30e-2;
L45 = 130.10e-2;
L56 = 57.30e-2;
L67 = 142.30e-2;
L78 = 48.30e-2;
L89 = 25.80e-2;
L910 = 21.60e-2;
L1011 = 5.50e-2;
Vtc = 15746.00e-6;
Atc = 1210.00e-4;
Ltc = Vtc / Atc;
Def_Driver 'Driver'
Sd=1210.00cm2
Bl=30.32Tm
Cms=8.96E-05m/N
Rms=9.91Ns/m
fs=32.0003Hz
Le=1.90mH
Re=5.30ohm
ExpoLe=1
System 'System'
Node=1=0=5=16
Node=1=0=5=16
Filter 'HP1'
fo=22Hz vo=1
{b4=1;
Filter 'LP1'
fo=83Hz vo=1
{b0=1;
Node=5=10
SD={Atc}
Len={Ltc}
Visc=0
Node=8=9
STh={S1}
SMo={S2}
Len={L12}
Conical
Node=9=10
Node=10=11
Node=11=12
STh={S4}
SMo={S5}
Len={L45}
Conical
Node=12=13
STh={S5}
SMo={S6}
Len={L56}
Conical
Node=13=14
STh={S6}
SMo={S7}
Len={L67}
Conical
Node=14=15
STh={S7}
SMo={S8}
Len={L78}
Conical
Node=15=16
STh={S8}
SMo={S9}
Len={L89}
Conical
Node=16=17
STh={S9}
SMo={S10}
Len={L910}
Conical
Node=17=18
STh={S10}
SMo={S11}
Len={L1011}
Conical
Node=18
SD={S11}
Not sure how often it'll will get used honestly, I just enjoy design/building/listening. I'm guessing it'll weigh in around 400lbs. I don't get the wood free (I wish) near me its about $60 for a 5x5 18mm BB, but there is always a discount for volume.
Why have you joined the two TH together?
You will get a 26.75*52*22.5 box that is much easier to move around @ ~55% of the weight.
it isn't going to be moved regularly. The weight isn't really and issue for me, so why not one large cabinet it will use less wood in the long run anyway
- Subwoofers
- A different route
