I think im gonna throw a party finally i figured out what was wrong with the amp. I had the mpsa06's and 56's in the wrong spots like i did the other 2 channels i reversed them and the amp works perfect thatnks again for all your help
Ok this amp is gonna be used for parts it was working fine. was playing it at mid volume and the transformer went . now the transformer is shorted out . I dont wanna rewind the thing and cant find a replacement anywhere and im not gonna sell the amp on ebay and give myself a bad rep not worth it
It would be a shame to part that amp out.
Can you twist the transformer to break the short intermittently?
ill try to twist it i dont really want to part it out ill try to twist or pull whatever i do to se if i can fix the problem first
If the problem is intermittent, it's likely that you only have a tiny bare spot on two wires and you may be able to get an insulator between them to salvage it.
Use a current limiter in the B+ line so you don't blow the PS FETs.
