A Couple of Simple Preamplifiers
Well, just the fact you listen to musicians means your circuits are very badly designed. However, I am sure they would be the best when you stop listening to audiophiles, musicians and other alchemists. They talk with their ***** and not their brains. Especially on sound.
Uh, we're trained engineers and you are obviously not. I am very objective and get a chuckle out of "audiophiles" that talk out their hindquarters.
I don't know what you're trying to accomplish by swinging your dick around here, but it's not going to work. This isn't twitter and don't you forget that.
Reactions: mchambin
I know about musician's circuits and I know they're different from hi fi. I've designed custom circuits (tone stacks and distortion effects) for musicians.
And how do you know about my circuits? I guess you don't.
Finally, you can add safety features without affecting the performance of the circuit at all. A properly designed safety circuit does nothing until parameters are exceeded, and does not effect normal operation at all. There is no reason in the world to design and build circuits without safety features, except ignorance.
In terms of safety, I am concerned with the safety of the circuit, yes. I should not cut safety for performance, but, I do. The most important point is to ensure the JFET, front amplifiers. I do not want to put diodes, because of non linearity and leakage. I prefer a large value resistors in series to the inputs. I think, 10K will be OK. 10K is, also, not as large as to introduce noise. In case the guitar can output a maximum of 3V, when the device is powered off, the maximum current which can get through is 3V / 10K = 300uA. This current may not damage the JFET inputs.
In regards to some amplifiers, such as Texas Instruments audio amplifiers, with built in diodes in the input, I would use a 3.3K in series to each input of the amplifier. Even in case all 30V go to an input, the maximum current would be 30V / 3.3K < 10mA. The built in diodes can take 10mA. This is shown in the ADOD.doc document, which, is JUST AN IDEA. Just a BLOCK DIAGRAM. I will make some evolution and variation of this, but, probably, in remote future.
In regards to protection of other equipment, I think, all equipment must be able to take + - 15V. Of course, the output can be limited or +- 5V power supply can be used. Most amplifiers would work at + - 5V, but, their parameters deteriorate.
The simplest output protection would be a resistor and Zeners before a buffer. True, Zeners are noisy, but, they may not be as noisy when they are off and they must be off to avoid distortion, unless, they are, also, used for overdrive, when, the noise is not as important. The noise can be eliminated or reduced by heavy filters after the Zeners and before the buffer.
Another protection I do not like, but, may need to use is a capacitor in series to the output to stop DC. I rely on the output buffer, which, must not have more than a few mV DC, even, uV in some cases. I do not know, I have not decided yet.
Tantalums were popular because they came in large values, small package, and (unlike electrolytics) low ESR and very high resonance. In the 70s they were like a magic bullet. Engineers stopped using tantalums because they blow up if too much current passes through them. They are much more delicate than electrolytics (which can blow up too).
Common film capacitors today far exceed what tantalums did or could ever do and they are far more robust. Nobody uses them any more.
I have never had problems with Tantalums, even, in industrial equipment. Only with a batch of Chinese, 25V, 10uF. The same value, 35V and 16V are OK.
Unfortunately I can not download your Preamplifiers.
But can you attach some file here in forum?
And is it alright if I post some simple preamplifier here?
I have a few.
When you click the link, you will be brought to a Google Drive folder. In this folder there are two documents. One of them, called " A Couple of Simple Preamplifiers.doc " is for preamplifiers, made in practice. They are simple, only 4 amplifiers in each as far as I remember. The other file, " ADOD.doc "has not been made in practice and has not been completed. Just a block diagram. I will make something alike. This will contain 10 to 20 and more amplifiers.
Obviously, the other way around. I do not think you know what you talk of. Neither do they.
Thank you but just one additional information. Your tone control in first schematics is not a real tone control, it's a filter tuning. That's interesting but it tunes only frequencies not gain. Please find a very simple but very efficient tone control for guitar preamp.
