A Carbon Fiber store!!
Besides inhaling the dust, carbon fiber is actually very easy to work. I make my drumsticks out of it, and the ends have to be rounded. Other than that, it's great stuff to use. A sheet of 200 to 250 grit sandpaper works well for final shaping before cosmetic buffing.
I made a headhsell out of two layers of thin dragonplate (carbon -ply-carbon) and it's as stiff as hell.
I'm thinking that i might make myself an LP12 clone using Dragonplate for the top-plate and carbon-foam laminate for the subchassis and armboard...
Should be fun..
Sorry no expert on plinth ,but carbon is good material for TT ,you can add a second layer C-ply-C later....
or a set of tonearm base in different material ,to tunning the sound ....
C-balsa-C under TT can work good or for motor base
