A Bridged TDA2050 for Single Supply
Need to make one for car use. No virtual ground possible...
Running from single +24V...
Will it:
A) Explode?
B) Smoke?
C) Do nothing?
D) WORK?
Yes, the zobbels...
Thanks for your help!
Can you attach an active filter to a chipamp?
I think you may have to do those separately.
Yes you can. But typically you take a unity gain active filter circuit,
and change the connection from the output to the unity gain point
of the feedback loop, i.e. connect the 3.3u to - in of the amplifier.
As shown the amp gain will make it oscillate like crazy.
To work accurately the lower feedback resistor has to be quite a bit
lower in value than the resistors in the active filter network I recall.
rgds, sreten.
check this out
just change the power ic to 2040 or 2050
YOUR ic can be an active filter by its self.....
The schematics are doing exactly what sreten suggested - using the signal from the inverting input for the Sallen and Key circuits.
Another possibility would be to use a voltage divider (two resistors) on the output - especially if you wanted to change the Q of the circuit by adjusting the signal fed back. (if signal fed back is greater than twice the signal in, with equal resistors and equal capacitors, you get an oscillator.) YMMV
