A big three way system based upon the Volt RV4564 18" Bass unit
Example shown of modest width front baffle with 18" woofer on the side.
The 8" Faital 8PR200 has gotten good reviews as a midwoofer.
The $64 Peerless 1" compression driver DFM-2544R00-08 can reach 20kHz.
The SEOS-12 would hold both horizontal and vertical pattern control for a 1500Hz crossover. A deeper horn like the LTH102 requires less high frequency boost.
Thanks for the above post.
Reviving this thread and with further investigations, I have come to a similar conclusion that side mounted woofer(s) probably now two 18"!! in force canellation configuration might be a better idea.
With the bass drivers possibly driven actively with an array separately mounted on top using a Volt 10" 2500.4 to a Volt VM752 3" mid and a suitable tweeter.
