I plugged in about 100 data points for Current (x) and ON-Resistance
for the Silonex NSL32SR3 Attenuator -- the errors for the very low currents are close to zero --
This is much better than the results using the Silonex equations.
Here's the equation - ymmv:
Can I assume that e5 = 10^5?
Yep, that is the notational custom - as I know it at least
On second thought...your formula is pegged down at 47R...it certainly can go lower![]()
the very low resistance points are the insertion loss.
do the math for a 0.5dB 100K+100K attenuator -- you need accuracy in the tens of picoamps in the part of the range where we do most of our listening.
And can also go much higher, I might add, and controllable too.
Not quite...with a more precise power delivery "engine"
I'll probably start a thread...
Several forms of equations will work -- but I have to say that the Silonex devices are all over the place!
Here's my setup -- using an LTC or ADI difference amp allows stable current in the picoAmperes:
Just curious if anyone has considered using this device
http://www.silabs.com/Support Docum...-evolution-drives-optocoupler-replacement.pdf
- Analog Line Level
- A better formula for Silonex LDR's
