a 640*480 4" lcd : good for videoproj?
Hello all!
I want to make my own video projector (to watch movies and maybe gaming) and i have found a 4" lcd which can support a 640*480 resolution with 18 bit colors ( 256k colors), but the problem is i haven't found a shop who selling them.
So i ask you if you have these lcd and if you know where to find i them. (i think it's interesting for many people , because small lcd don't need much light to project a good picture, and we can directly perform a lens like delta IV or fujinon without any fresnel.
Kurush.
edit: sorry i haven't give you the link: http://www.purdyelectronics.com/ANDDisplays/tftmodul.cfm
it's the ANDpSi04C380K-HB (the first in the chart.)
Yes this is a tft module, without controller.
If i want a controller which can have a 640*480 resolution with 6bit/color, how does it cost? i just want a vga input and output for lcd (no inverter for backlight, contrast adjust or other...).
Maybe i can build one? i can make the pcb , but i need components and schema, if one of you have that... tell me!
Argh!!!
Item Details Stock Details Pricing Add To Cart
Mfr.'s Part #: ANDPSI04C380K-HB
Allied Stock #: 769-2007
Manufacturer: AND
Description: Liquid Crytal Display, Color TFT Modules with Backlight
Current Page #: 478*
Previous Page #: NIPC
Qty. In Stk.: 1
U / M:
1 Ea.
Min. Order Qty.: 1
Request Lead Time
1-2 $539.2000 Ea.
Is it real american dollar? or another ? because it seems very expensive!!! 539 $ without controller!!!😡 😱 :bigeyes:
:bulb: i think i have found the solution for control the lcd, i will not use the vga connector , but my dvi-i connector whch is on my radeon 9500 pro. I have found some dvi->lcd controller and they haven't so many components , like that
if it works, i would be able to control all lcd module i want, and it would be less expensive, because the controller is the more expensive in lcd, (but not like as the AND lcd ....🙂 )
so if somebody can tell me how to build a dvi to lcd controller ....
don't hesitate 😎
the AND lcd id too expensive, and i have found a toshiba lcd whiwh have the same specs:
4" lcd P-si
640*480
256k color
5.2% transmissive
driver on glass, so we just need a controller with 27 connector (it's the same pinout as the AND lcd, so it's maybe a standart pinout for P-si lcd , i think)... The cost was 500$ in 2000 but now people can found them at approximately 250$.
Now i must found a controller.
I want one which just convert dvi signal to the tft signal, and i can make the pcd to build it. So i have to found a site who explain how to make a dvi to lcd controller.
Excuse me, it's not what i wanted to say, i haven't found a site like that, but i seek for one, i want a controller card for lcd which convert dvi to lcd's signal.
edit: If somebody know where to buy lcd (just the display, without controller and backlight... I'm interested.
