9v AC power supply for DAC
I have a small DAC board which requires 2x 9V AC.
Ie. the board has terminals marked: [9V - 0V], [9V - 0V]
Rather than having to drill and punch holes in a chassis for an IEC style socket, is it possible to use this plugpack:
Altronics - M9231 Powertran Appliance Plugpack 9V AC 0.67A
And then simply have a 2.1mm socket on the chassis?
Presumably I could take two wires from the centre tip to the 9V terminals, and then two wires from the sleeve to the 0v terminals.
Would this work, or will I require two plugpacks?
FYI - current drawn by the DAC is 60mA.
