I'm looking for a kit that uses a +/- 80v DC power supply, and its capable of close to 1000 watts of power.
What is the best amp I'd be able to buy off ebay and try ?
Thanks.
Srinath.
Thanks.
Srinath.
That power supply voltage could only yield 400W into 8 ohms, and 800W into 4 ohms
(with enough current capability).
2000 watts ??? 2500 watts ??? man this thing will be a smouldering pile of slag long before it gets 1/2 way there.
It has a super optimistic 10 amp fuse on the main power input. I would bet its barely capable of 1000 watts, assuming 80% efficiency, barely 1000 ... Rayma's numbers are probably accurate in the best case scenario.
But I will look @ those IRS2092's and see what they can do.
Thanks.
Srinath.
Thanks.
Srinath.
Overly optimistic specs aside, they still fit your criteria for supply voltage. 😉
I have a Tripath TA0105A reference board that's been sitting for around 8 years unusued. Some day I'll put it one of these AudioSource AMP7T chassis I have, since all of their TA0104 modules fried.
wattage and cost
The 2000 watt one is $299. I am going to use it like to 1/4th of its potential.
Why are the other lower wattage IRS2092's operating off lower supply voltage.
Thanks.
Srinath.
Thanks.
Srinath.
How about this one -
2X 250W Class D Audio Amplifier Board Amplifier IC IRS2092 Sure AA AB32291 | eBay
I'll ask them for confirrmation if it will work @ 80v. Also when the amp is under no load it is 80v, what would happen if we draw 500 watts from it ? it would drop right ?
Thanks.
Srinath.
Thanks.
Srinath.
Because a lower voltage means a lower output power for a given load.
Your power supply will sag some under load; how much it sags depends on the power supply. The biggest problem is that since +/-80V is the MAX supply voltage of the board, bus pumping could cause the over-voltage protection to trip.
Are you trying to work around a power supply you already have? Is it transformer based or switch-mode?
Thanks.
Srinath.
This is not a kit but have a look @ this JLElectronics board.
2pcs Blank PCB Mono JLE 2000D Class D Amplifier IRS2092 IRAUDAMP9 Based | eBay
His support is outstanding
I have a dead SAE A205, with 50v and 80v switchable Toroidal trafo. The corresponding outputs are 100 watt and 200 watt.
I can run it @ 50v permanently, but that would mean it would barely break 200w output, besides I have several dead amps with around 50v EI core trafo I can use.
I am still trying to repair it, I cant find an issue in it, nothing burnt nothing looks off, and its making no sound except for a tiny tiny crr in 1 channel as I am turning it off.
Its got 20 mv DC in 1 channel, and essentially 0 in the other. Something in the signal path is dead, but how can it happen in both channels, and they dont share nothing in the signal path, no crosstalk, I even suspected the RCA jacks, but I have varying AC voltage @ the input.
I'll look into some of those kits as well, I am very much hoping to fix the amp without grafting another kit amp in it.
Thanks.
Srinath.
Thanks.
Srinath.
I heard this can give a lot of real power cheaply also not much rail capacitance is needed: IRS-3000D
Thanks, I found the ebay store for that amp. I'll look into it, I am hoping there is a simpler reason why my amp is dead though.
Thanks.
Srinath.
- Class D
- 80v DC amplifier kit
