I noticed the 8 inch 2way combo has a bit of a following over at DIY. Is there much buzz around these ones? Energy 22 Loudspeaker System Manual | HiFi Engine
I'm getting a pair midweek. I knew of them, but have never tried those particular Energy's.
If someone can clarify there was 3 models at the time, and the RC were mid tier?
They spec 200 watts power handling. Which seems nice, I wasn't expecting quite a high rating for these little numbers. There not the most efficient. That should be okay I have something that should be powerful enough.
Was it the RC that get the problematic tweeter fluid by the way? Or did all of them require a fluid job in order to function properly?
