8 Watt - SINGLE END solid state
I seached the web, and came across a very interesting homepage.
It is a private norwegian guy, Nils Strøm.
He has only 2 projects, but both are very interesting, I think.
Single End 8 Watt Solid State Amplifier,
without global AC feedback.
Also a High End 20 bit DAC, using parallelled PCM1702.
Battery Powered Analog part of the Circuit.
Links:
Nils Strøm, Norway - Homepage
Single Ended Solid-State Amplifiers
20 bit High End DAC with PCM1702 - pdf
Below is the schematic to the unusual 8 watt SINGLE END solid state amp.
This schematic is also at my FTP-site now.
/halo - Big FAN of Norway! 😉
Great effort, but horrifically complex for the job it is doing.
Slavish use of CFPs throughout without too much regard for the linearity of the output stage whose driver will have a widely varying current.
Probably sounds OK; CFPs at constant current are reasonably stable. Input stage seems very complex; can't see the point of going beyond a simple diff pair, myself.
Hugh
