750VA Torid 120V/55V+55V
thyristor soft start? Can you post a schematic?
Diac and Thyristor are often used to fire a relay, not to absorb/reduce a start up current pulse.
A resistor or thermistor are more often used to soft start a toroid transformer.
A thermistor can only be effective if it is cool. This needs some time and does not suit flakely power supplies that could repeatedly brown out over a period of seconds. I will be using resistor type.
