7.1 class a sorround system
Hello to all. I have recently acquired a heatsink with a thermal resistance of 0.012 k/w. It is a very special heatsink custom designed for high power devices. I would like to create a small dolby sorround system. My only limitations are:
Max 1000w total heat dissipation
8 modules (need not assemble all right now)
Common voltage requirements to all the modules.
I thought of aleph 30 but are there better alternatives? Use will be for movie sound in a mefium sized living room.
Thanks.
Inviato dal mio GT-I5800 usando Tapatalk
I guess i should have been more precise.
I am currently using 90db sensitive satellite speakers rated at 15w each from an old pc sorround system. However i find myself in the odd position of beinv between systems. I will certainly upgrade the system but i don't know when exactly. I was hoping to have an idea for a system which will most probably deliver with any system of sorround speakers. The real point is that i really want to use this heatsibk. You will see just how compact it is and with forced air cooling the performance should be exceptional.
