6V6 line preamp
Happy Easter. Looks like it will be working good enough as a series reg, although not very sophisticated on the self noise department. Check out Keantoken's HV capacitor multiplier filter too when considering series solutions. Not a regulator, it will follow input level changes slowly. But it will filter rail hum with low output impedance, and will not ask for that choke. Takes two, one for each channel since it can only do up to 30mA safely. Look there under "Other adaptions of the Kmultiplier" The K Multiplier
Thank you Salas very muchi!! I will read and study Kmultiplier to choice the solution to reduce rail uhm.At the moment the pre work in a little wood box that Was a package for red wine so i expect a new supply stadium and a better package before show it.
I am concerned as I will be running this to dual mono amps and might have a pretty good run of interconnect. Balanced is just so useful in this regard. If i put the pot in between stages, I would assume this would replace the 470k resistor? or would i just add it and increase the coupling cap to maintain desired bandwidth?
I would need a different reg for each filament, correct? Is it a better choice to have these regs powered by seperate transformers? or can I just use the secondaries that coem with main transformer. Also, I notice the cathoe follwer version has a B+ that is 10V less. Can i just insert a resistor in between the rail and plate of that tube to lower the voltage 10V?
Sorry for the questions. I want to do this right the first(second🙂 time and be done.
Those things are just about how separate PSUs and expensive you aspire your build to be. Common or separate power sourcing will basically work. If its CCS heaters got to be separate though else they will not balance Vh correctly. Not heater trafos, IhCCS circuits.
Using a pot in between its intuitive. You choose a Cout that can drive it well down to infra bass and you wire it instead of the output 470k as if the first stage was some source gear. Same stuff.
Same B+ will work OK.
Bias is bias, has not to do with the pot. Why you wanna use such a high value pot? There is still input capacitance in the tube even when not in gain mode, so much series R will truncate the bandwidth. See with a scope that it passes a 20kHz square nicely in any case.
Salas i Made some mesurement today: i have 300v on anode, 23mA , on cathode 90v and the grid Was -30v respect the configuration is cathode follower.
do you think the valve work in the correct zone? I observed a current variation of 0,3mA at max and a voltage variation of 3volt.
So other question is could the serial regulator improve something or i have to consider other action for seriously have result s on sound?
