6sn7 operating points
whats a good operating point for an input stage?
probably not bypass cathode resistor.
will be cap coupling to 6BX7 into a 1:1/1 phase splitter tranny.
power supply voltage is around 260v.
Is 100-130v too low for plate voltage on 6SN7? voltage output will be very low so does it really matter?
will be for a 6SN7 cap coupled to 6BX7 to drive PP 6B4G's.
any help would be appreciated as I don't know that much about 6SN7's and 6BX7's except what is said about how they sound.
what do you suggest?
ok i can change it around...
for 250-260v supply voltage with the 6SN7 resistor loaded with NO cathode bypass cap..
what would be a good RL and bias point?
actually given that the 6B4G's need about 60v grid and the 6BX7's gain is about 10 then 6v output of the 6SN7 is all is needed.
Thanks for any info!
andyjevens
I believe the Jeff Korneff preamps uses that configuration. I heard those preamps- very nice. I built a simple 6P5GT RC coupled preamp & it sounds very good. I would need the Korneff preamps next to this new DIY 6P5GT with an A/B test to test for best sonics. Anyways, very close to one another.
The 6P5GT I like are all round plate including Tung-Sol, RCA Cunningham & Sylvania in that order. They are all very close to each other in performance.
> At that voltage, you'd probably want to use ...
I think Richard was getting the 60V from 6BX7 with transformer coupling, a fairly reasonable proposition.
Then his question is how to drive 6V into 6BX7 with 6SN7. At 6V signal and 250V supply, 6/250= 3%, we are not really near the 10%-20% range where we have to optimize. With tight layout and no NFB, 6SN7 with 220K and 90V at the plate will work for 6V to 20KHz.
For maximum output we want the plate load somewhere between the saturated Rp and the next-stage Rg. Say Rp=6K, Rg=1Meg, calculate 77K, use 47K. Bias the plate at 0.5 to 0.7 of B+, say 120V to 170V. Expect something like 20% of B+ as peak voltage: about 50V peak. As you point out, an R-C driver is not quite enough to slap a 2A3/6B4 working on the same supply rail (it is marginal with cathode-biased 2A3/6B4). That's probably why the transformer-coupled 6BX7 is in there: it could easily slap 160V peak from 250V rail.
For maximum gain from the 6SN7 stage, use a very high plate resistor, almost as big as the next-stage Rg. Say 470K. Then run as much current as possible while still making your output swing. That can sometimes be 50V or less on the plate. But at this impedance, stray capacitance droops the top of the audio band, and this low plate voltage may not be stable with age or tube-swap. And many classic triodes "bend" around 50V. 100K-220K and 70V-120V is a better bet. Gain will not be much less than the max-gain case (and gain was not demanded by Richard), things can drift all over and still leave 6V headroom.
It is sorta a case of: hard to go wrong. Dang near any bias point will work. I'd be more concerned about the parameters of the coupling transformer: 6BX7 is beefy, but a poor choice of transformer will strain it, and to get real beef in 6BX7 you need good DC current which strains the iron. That core and its windings becomes the pivot of the whole amp.
well thanks!
i looked at the standard charts and drawing a load line from 260v... 30K load line (3*Rp)... looks pretty linear around 4v bias 150v plate and 6mA.
Remember i just need 6v out of it.
Hey, if it sounds bad i can always change it.... since RC coupling to next stage.
btw, should I put a cathode bypass cap on the 6SN7?
and finally, the 6BX7 will be driving a Electra-print phase splitting IT. gotta email jack and see what they are rated for. at least 25mA i believe... and thats what I am going to run.
Thanks!
Gain will be low, and distortion not as low as it could be.
But you may already have all the gain you need, and the first stage's distortion is sure to be very small compared to the driver and output stages.
My main objection to 30K 6mA is that the first stage needs the best-filtered power. Given a choice between a 1mA stage and a 6mA stage, the 1mA stage needs 1/6th the power filter capacitance for the same buzz. True, the cost is not large either way, not compared to the overall amp. And you are not building for Profit (commercial designs often starved stages to shave pennies in power filtering).
Bah, don't think too much about small details. Big details that will derail the project if wrong, that's where you should do the hard thinking. But a cathode cap is a $0.25 problem: if thinking-time is money and you think about it for a few minutes, you are wasting money. Buy the cap, leave space, then try it both ways. The main difference will be ~5dB of gain: this alone (how it matches your signal source strength and listening levels) may be the deciding factor. If the stage were working harder, it would affect THD and bandwidth, but this stage works so E-Z that it hardly matters. (Obviously if you were going to make a million units, knowing in advance if you needed a million $0.15 caps might justify a LOT of thought.)
Yeah, if you decide you like the gain with a $0.25 cap, you might wonder if a $25 virgin-silver cap would sound better. But if you like it best without the cap, that question never comes up.
anyway
i have 6 47/47 500v elna cerafine caps (before they went expensive)...
so I could always add an extra cap for filtering for the input stage as it needs it more than the output.
The output is not as important due to the PP topology.
It's very interesting. I stuck in the same thing. Reference design of common cathode cascade from the datasheet works at very low currents, <1mA and quite high bias, about 3-4V. Many existing designs, including Broskie's ones, works at 5-8mA with the same bias.
Sounds like a perfect situation to use a CCS instead of a plate resistor. shoot for about 6-8mA with around 170v on the plate. From my experimentation this is a great spot to run the 6SN7/6CG7 types, and the CCS will get you a nice high impedance load for linearity., especially considering you aren't swinging very much signal.
Cascoded DN2540, an IXCYS device, or a PNP tranny setup would do well.
Yes, I'm talking about a CCS load. But 6mA vs 0.6mA makes some difference. SPICE simulation shows that linearity improves with lower current and higher bias.
The 6SN7 is a neat tube, and it can do some suprisingly good things at low current. If you check the table on page three of this datasheet-
http://www.mif.pg.gda.pl/homepages/frank/sheets/093/6/6SN7GTB.pdf
You can see it can actually get a ton of swing from higher load resistance, so running it low current does actually seem like a reasonable way to get some nice numbers out of it. How the harmonics stack up is a different story, and one I am unable to measure or comment on due to lack of tools and experience at such operating points.
