Re: nice work
Try the AV5 as pentodes. put g2 at ~70V. They do well as linestage tubes too. B+ of 200, g2 of 75, 100R cathode R and 750R plate loads....sweet!
cheers,
Douglas
jrdmedford said:Also from Boston. We've talked before at some point. So whats
next??? I can help you out with getting better results with the
metalwork. I'm a whiz at FPE designer.
Amity Clones
The amps in the photo use MQ-565s, the Triode Electonics ST-35 power tranny clone. The itself is an Amity clone. I'm using 12AV5's strapped Triode (look like 2A3s), 6AX4 damper rectifiers and 12BH7 as drivers.
The top plates cost $170 to fab a pair (lots of countersunk holes). You can get the Walnut boxes for another $140.
For you next trick, you should do a Triode KT66 or KT88 PP amp.
-- Jim
cheers,
Douglas
