Hi all,
I am thinking about an output stage for my (dvb-project) tda1541 DAC. I have an SRPP output stage based on 6n16b lying around, including transformer. If possible I would like to test this one on the new dac. Can someone verify the below calculations for i/v resistor?
Gain for the tube is 20-25 in SRPP
Output for the tda1541 is 4mA, I use 2 so that will be 8mA.
How do I calculate which i/v resistor value to use?
