Hello everyone?
Has anybody played with 6M11's? I'm guessing the Sharp-Cutoff Pentode
could be used as the first stage, going into a Triode and then using the other Triode as a phase inverter. Any thoughts?
Ray
http://scottbecker.net/tube/sheets/093/6/6M11.pdf
Ray
I found them inconvenient: pentode looks more like semi-remote cut-off, so relatively high current would be needed, like 15 mA.
However, YMMV...
However, YMMV...
I've used one in a LCR phono pre. I ended up going a different direction, but it didn't sound half bad. See link below
http://www.intactaudio.com/forum/viewtopic.php?p=2954&highlight=6m11#2954
