For a push pull amplifier, the datasheet calls for a certain amount of plate current for two tubes. When the data sheet says "values for two tubes," does that mean that both tubes are drawing the datasheet value individually or is the datasheet value the combined plate currents?
It´s always confussed
I found that same at many datasheets. I reached conclussion that the values is for two tubes but just for some: usually pick to pick grid tension and power; the rest is just for single tube. This could be expossed better in the datasheet.
Usually, they're pretty clear about when they mean one or two tubes; there will be separate sections for single tube conditions and push pull. In the case of voltage ("tension"), it doesn't matter. Can you give an example of a datasheet where you think it's ambiguous?
