6Э6П-E and 6Э6П-ДР spice models
Yes that is correct, but anyway I built the triode model as requested.
Code:
**** 6E6P-T ** Advanced Grid Current **********************************
* Created on 06/14/2022 04:15 using paint_kit.jar 3.1
* www.dmitrynizh.com/tubeparams_image.htm
* Plate Curves image file: 6e6p-e-t.png
* Data source link:
.SUBCKT 6E6P-T 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=15P  CGP=0.05P CCP=5.9P
+ MU=33.95 KG1=37.3 KP=398.95 KVB=1941.84 VCT=-1.469 EX=1.098
+ VGOFF=-0.6 IGA=0.00107 IGB=0.201 IGC=9.92 IGEX=1.66
* Vp_MAX=200 Ip_MAX=140 Vg_step=0.5 Vg_start=0 Vg_count=11
* Rp=4000 Vg_ac=55 P_max=8.3 Vg_qui=-48 Vp_qui=300
* X_MIN=16 Y_MIN=64 X_SIZE=865 Y_SIZE=598 FSZ_X=1296 FSZ_Y=736 XYGrid=false
* showLoadLine=n showIp=y isDHT=n isPP=n isAsymPP=n showDissipLimit=y
* showIg1=y gridLevel2=y isInputSnapped=n
* XYProjections=n harmonicPlot=n dissipPlot=n
E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G  ; TO AVOID FLOATING NODES
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G   ; TO AVOID FLOATING NODES
C1 2 3 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
RE2 2 0 1G
EGC 8 0 VALUE={V(2,3)-VGOFF} ; POSITIVE GRID THRESHOLD
GG 2 3 VALUE={(IGA+IGB/(IGC+V(1,3)))*(MU/KG1)*(PWR(V(8),IGEX)+PWRS(V(8),IGEX))}
.ENDS
Looks like the wrong scaling factor was entered in the paint_kit program (20 mA/div instead of 10 mA/div). The tetrode model shows very high screen currents as well, so that the sum of plate and screen currents (when triode connected) is double what it should be.
Reactions: Koonw
Thank you for pointing out. Here is the correct model:
Code:
*** 6E6P_E_T ** Advanced Grid Current *********************posted correction*************
* Created on 06/15/2022 09:28 using paint_kit.jar 3.1
* Data source link:
.SUBCKT 6E6PE-T 1 2 3 ; Plate Grid Cathode
+ MU=33.95 KG1=74.23 KP=398.95 KVB=1941.84 VCT=-1.469 EX=1.098
* Vp_MAX=200 Ip_MAX=70 Vg_step=0.5 Vg_start=0 Vg_count=11
RE2 2 0 1G
.ENDS
