6DJ8 Tubes
One Caveat on the above points re 6ES8 (ECC189).
They actually make a good cathode follower on a line out stage - because of their non-linearity. Run them at around 6 to 8mA. As the output voltage goes up they start putting in some 2nd harmonic distortion. Not too much because there is nearly 100% feedback in a cathode follower stage. I like it that way - it adds a bit of warmth and "tubiness" and is absolutely ideal for driving a SS Power Amp.
Hint: run the 2nd triode in an identical circuit , active but inverted drive, as a "pseudo" shunt reg.
Where linearity is required stick to ECC88 - of the modern production stuff I like the JJ.
I have had bad experiences with microphonics with NOS Philips. I have a prototype amp with 6DJ8 cascode diffamp / direct coupled 6SN7 cathode followers / Parallel Push Pull KT88 Ultralinear (135W in 4 Ohms with Hammond 1650T Output Tranny). It took me ages to twig that that low frequency "surf like" woosh woosh was microphonic 6DJ8 in the diff amp.
Ian
