Hi all,
Just for sharing my experience with 6db serial two ways crossover.
filtre 6 db série 2 voies, xover serial 6 db two ways
Thank's in advance fo comments or suggestions..
Phil.
Phil.
I drew quickly a schematic :
Hi Phil, nice job.
Funny is that I ended in some similar design, well, just a coil and a cap.
I used the same 12 uF value but with a different driver, a Monacor SPX-20
which is a tiny 2" coupled to a 7" waveguide.
I see also hat you fixed the coils to the panel with a screw
you should use some non ferro-magnetic materials, or better, glue, or, optimal,
leave the crossover out of the box!
- 6db serial two ways xover
