The main Svetlana entry page is gone, but all the other pages are stilll there
http://www.svetlana.com/docs/tubeframe.html
Does someone know what happened to Svetlana in the States? I found the following note on http://store.yahoo.com/triodeel/index.html
Note about "SED" Tubes: These used to be called Svetlana before a legal dispute forced the factory to quit marketing under the Svetlana name in the USA.SED's are the same tube, same box, same "C" logo, made in the same factory in St Petersburg, Russia as before. Note that there are tubes not made in the St Petersburg factory that are sold, legally, in the USA as Svetlana tubes.
Cheers
Cheers
Comrade Pjotr,
Svetlana made tubes are now available as Winged C amongst other names, I presume.
The distribution is being negociated by P.M. Components ( you know, the Golden Dragon junk triad).
I heard rumours of Svetlana being in financial trouble, the Svetlana brandname issue in the U.S. seems rather unlikely as an explanation.
Here's some more info: go to the "Tubes" menu and click "Winged C".
AES
Comrade Pjotr,
AES
GAK, there are a lot of alternatives to the 6D22S too, such as the EY500A and others like the 6CJ3 which don't need a top cap. The 6D22S is nothing special in it's class, except for being the only one still manufactured, but there is a ton of NOS dampers out there available cheap.
Brett
Thanks for the alternatives.I'm planning to use the 6D22S for a full wave rectifier(2 of them) for my ECC82 SRPP preamp.I need something good giving plenty mamps.
I'll use 3 p-filter(30uF MKP-10H-200uF MKP split to 7H-200uF to the R channel and 7H-200uF MKP to the L channel)
I haven't decided which rectifier to use ,yet.So any suggestion is acceptable.
Without topcap:
6AX4 are plentyfull as well.
With topcap.
I have been using EY81...but have been running them for 3 months now without a cage...which is pretty stupid..since kids or adults for that matter can be fried if they touch the metal parts that are still exposed!
Bas
With topcap.
Bas
- Tubes / Valves
- 6d22s
