The 6CJ3 has two pins for plate, pin 2 and 7. Do you guys connect only one pin or both pins ?
H HP8903B Member Joined 2010 2013-02-19 3:12 am #1 2013-02-19 3:12 am #1 The 6CJ3 has two pins for plate, pin 2 and 7. Do you guys connect only one pin or both pins ? Attachments 6CJ3.pdf 182.3 KB · Views: 59 ••• More options Share Chris Hornbeck Member Joined 2011 2013-02-19 3:43 am #2 2013-02-19 3:43 am #2 Either one is fine. All good fortune, Chris ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button.
