Is there a better way to determine bias point and grid volts for different Vg2 volts besides looking at the Vg2=250V curves and guessing?
Sometimes I have made pure experimetal tests by having all variable voltages (supply-, g2- and -g1-voltage) for a tube under test and also variable load resistance.
Then all required combinations can be tested and the results are fully "live".
I see this as the best way if not suitable data is available.
I have used this method for some soviet-made output tubes with good results.
Ofcourse this requires that one has some test equipment available.
