I've just found some 6aq5 tubes lying around, and looking at the gain of these things they have just about the right gain in triode mode for a (much needed) line stage. They should also have more than enough grunt
Problem is, i have no experience designing tube circuits, and this is far from the normal application for these things. I've searched everywhere but can't find a thing.
If anyone could help me out with component values, i'd be most appreciative
Thanks,
Hamish
Thanks,
Hamish
What do you have available for a PS, and at what voltage? That'll be your starting point to determine what you can easily use for the B+, unless you're willing to get something made (muchos pesos in Oz) or use surplus.
It's unlikely many people have used this tube in this application, but I can't see why it won't sound good. Trouble is, you're going to have to find the op point yourself (which is why I asked about the PS).
An OTTOMH suggestion to start would be B+ = 400V, Ik = 30mA, Va = 150V, Rl = 8k (20W), or 300V B+ / 5k.
Thanks for the reply, Brett. I've been meaning to build your 12B4A line stage but got side tracked with silicon 😱
It's good to get a little validation on the design. Seeing noone had used it before had me worried, but you've gotta try everything at least once (except folk dancing).
As for power, i've got a 250-0-250 little transformer (rather poor quality) that was in the AWA receiver that i got the tubes from. I also have a 350-0-350 R-core moster i bought a while back for the 12B4A that never was.......yet.
I figure if i can get this working with some junk stuff, then i can splash out a bit more on some real hardware.
Thanks again,
Hamish
Thanks again,
Hamish
It's not a bad little design. If you get around to it, I hope you like it.Hamish said:Thanks for the reply, Brett. I've been meaning to build your 12B4A line stage but got side tracked with silicon 😱
I don't know that it'll sound, good, but I suspect it will. The 6AQ5's I've tried recently in another project were very good, and as a lot of people don't use them, cheap too.It's good to get a little validation on the design. Seeing noone had used it before had me worried, but you've gotta try everything at least once (except folk dancing).
I threw some estimate numbers into PSUD for both transformers and for simple SS FW rectification, got 420 and 320V for both channels off a single supply @ 30mA/tube.As for power, i've got a 250-0-250 little transformer (rather poor quality) that was in the AWA receiver that i got the tubes from. I also have a 350-0-350 R-core moster i bought a while back for the 12B4A that never was.......yet.
Measure the transformer secondaries and futz with the numbers to see what you get. Even with the big one, and a couple of RC stages the 300V op point I mentioned is viable, if you don't mind a few extra watts of heat.
Everything I've suggested is available cheaply through local suppliers. If you like it this way, then I'd suggest using a FW with a 5AS4 or similar, LC (+LC if affordable; Hammonds are cheap) off the 700Vct transformer. Then by changing a couple of resistors and sockets, you can try the 12B4A too.I figure if i can get this working with some junk stuff, then i can splash out a bit more on some real hardware.
Thanks for your replies. I've modelled a few in PSUDesigner, and for now trying to get an CRCRC filter to work with R values of a sensible wattage. I want to try and use the cheap transformer, as i have the big one still planned for the 12B4A. I see Evatco have some reasonable open style chokes for around $30 a piece.
I'm just working my way through a tube design book now, so hopefully i'll be not so much in the dark. I found the sticky thread for newbies, so i'm devouring everything in there for now.
I do have to admit the 6AQ5's 8% THD is a little disturbing.....but this is a first project 🙂
Thanks again for your help and guidance, Brett 😉
Cheers.
Cheers.
If you're going to use a SS rectifier, simply add a 100u cap at the first position. That got me the 320V I mentioned earlier. I like to use the constant current option for the load (even though I know it's not CC); in this example 60mA. Look at the voltage at the CCS, which is 20V high for the 300V op point. The R should be 20/60mA = 330R. I'd probably split the supplies after the first cap and run a seperate RC for each tube; say 650R and 220u. Not the best supply in the world, but it'll work and give you an idea whether it's worth refining the design.Hamish said:Thanks for your replies. I've modelled a few in PSUDesigner, and for now trying to get an CRCRC filter to work with R values of a sensible wattage. I want to try and use the cheap transformer, as i have the big one still planned for the 12B4A. I see Evatco have some reasonable open style chokes for around $30 a piece.
The open frame Hammonds are quite good, and the 193's good for poweramps.
As I mentioned in the last post, you can build this using the bigger trans, and with a 4 resistor modification and some new sockets, use the 12B4A's later in the same setup. Just don't build it all fancy until you finalise it
You won't get but a tiny fraction of that trioded, working into a modest load and swinging the huge 1-2V a linestage will give.I do have to admit the 6AQ5's 8% THD is a little disturbing.....but this is a first project 🙂
My pleasure.Thanks again for your help and guidance, Brett 😉
The 6AQ5 is similar to the 6BQ5/EL84 which i have seen mentioned for use in triode mode in a line stage.
dave
dave
Actually, the 6AQ5 is a 6V6 in a seven-pin miniature envelope, so trode-connected it should sound fine. Any triode that makes a good driver for a DHTSE output will usually make a good line out with suitable transformer when using longggg cales.
John
I actually wanted to try and avoid using an output transformer, and just go with a cap. I've found a couple of schematics using similar tubes in triode mode for headphone output (also some for the 6BQ5 (thanks for the tip, Dave), which i seem to remember are lurking inside my Akai R2R
Yep. And even better in {real} amps, ie PP's too.jlsem said:Actually, the 6AQ5 is a 6V6 in a seven-pin miniature envelope, so trode-connected it should sound fine. Any triode that makes a good driver for a DHTSE output will usually make a good line out with suitable transformer when using longggg cales.
The 6BQ5 is an excellent tube, but it generally has too much gain for a linestage, unless you Tx couple the output, which I think is a good idea anyway. Use Lundahls.Hamish said:I actually wanted to try and avoid using an output transformer, and just go with a cap. I've found a couple of schematics using similar tubes in triode mode for headphone output (also some for the 6BQ5 (thanks for the tip, Dave), which i seem to remember are lurking inside my Akai R2R)
Do you use Circuit Maker Student to model your designs?
Here, I made this model last night of a triode-connected 6AQ5A - go nuts! 🙂
Use Notepad and just paste it in at the end of your "triode.sub" file in the "models" folder.
Code:
*Vacuum Tube Triode (Audio freq.) pkg:VT-7 (A:1,2,3)(B:6,7,8)
.SUBCKT X6AQ5A 1 3 4
B1 2 4 I=((URAMP((V(2,4)/8)+V(3,4)))^2.25)/15000
C1 3 4 8.5E-12
C2 3 1 8E-12
C3 1 4 0.4E-12
R1 3 5 10E+3
D1 1 2 DX
D2 4 2 DX2
D3 5 4 DX
.MODEL DX D(IS=1.0E-12 RS=1.0)
.MODEL DX2 D(IS=1.0E-9 RS=1.0)
.ENDS X6AQ5A
Looks like a good place to start. If your source is clear of DC, ditch C2.Hamish said:Here's what i've got so far, please let me know if i'm on the right track (probably not).
Brett, does "your" 12B4A linestage invert phase if used with a standard capacitor output?
If yes, can this be fixed by reversing the output wires from the transformer when used in a parafeed construction?
Hmmmm, not bad Geek. I might give it a try, but as i only have two tubes, one half of my stereo might get lonely 🙁
In relation to the above post, does running it as a triode with a cap output reverse phase?
Thanks for all the help, guys. i'll let you know when i get it all slapped together.
Yes, as do all common cathode stagesbequerel said:Brett, does "your" 12B4A linestage invert phase if used with a standard capacitor output?
Yes. But why not simpy reverse the speaker cables if you need to swap absolute phase rather than adding an output Tx?If yes, can this be fixed by reversing the output wires from the transformer when used in a parafeed construction?
Great. Keep us up on your progress.bequerel said:Thank you, Brett! I am just about to start my 12B4A Preamp project 🙂
Brett , if you are still with us on this thread:
I will have approx 125V (calculated) on the plates after the CCS in my 12B4A linestage.
(150V stabilized with 2xVR75 tubes - 25V loss in the CCS = 125V)
What would you suggest as an suitable bias point with the 125V plate voltage in mind?
Sorry for hijacking the thread!
- Tubes / Valves
- 6AQ5 Line stage?
