Hi everybody..
I'd like to know the output impedance of my tube preamp, using a web calculator, but i need to know Ri and gain of 6922 and for me (newbee) it's still too complicated to measure these values.
Is there anyone that have indicative values about this?
Thanks in advance guys!
Marco
Marco
What are the plate and grid voltages?
And also the schematic diagram. The tube's operation depends to a large degree
on the associated resistors, capacitors, and power supply voltage.
i haven't the real schematic, the only one that i have received from seller is wrong.
I should be check the pcb and try to draw real scheme.
Can you post clear, close photos of the front and back of the pcb?
The bias voltage, if it is self-biased, then it is the cathode voltage.@Jazbo: what do you mean for "grid voltage"?
- Tubes / Valves
- 6922 Technical info (help)
