6550 Users Beware...
diyAudio Senior Member
Joined 2002
This morning I received an e-mail from Bruce Rozenblit (Transcendent Sound).
Apparently the metal base version of the Svetlana 6550s have this base connected internally to pin # 1 which in turn is connected to pin # 3; the anode/plate.
This obviously exposes any plate voltage present so touching both the base and chassis can present a lethal hazard.
The original mesage can be read here:
MESSAGE BOARD.
Please follow the advise given by Mr. Rozenblit and make sure no plate voltage remains before you pull out the offending tubes.:att'n:
Cheers,😉
