60Hz buzzing
diyAudio Chief Moderator
Joined 2002
So you have a PSU ground and no signal ground to chassis. Please get crocodile clips and a 10 Ohm resistor. Attach one clip to an input RCA ground side and through the 10R attach around to chassis and see what happens. Do L&R channels test zero R when you probe L & R input RCA ground sides?
Ex-Moderator
Joined 2003
whitelabrat said:
It's a very sharp buzz rather than a mellow hum. Not that it makes a difference.
Oh yes it does. A sharp buzz suggests problems with reservoir capacitor current pulses producing voltages where they shouldn't. There should be one loop connecting the reservoir capacitor to the rectifier and the load should be connected across the capacitor - never anywhere inside the loop.
Joined 2002
whitelabrat said:
Once again thanks everyone for their help!
I double checked the polarity going into the power transformer. Oll Korrect there.
I then connected a 20ohm resistor to the input ground and then to the chassis. Most of the buzzing disappeared. Just a very low warm hum remained.
Way to go! Ground loop Zzzz nailed. Now hunt around that PSU ground related hum. Is there any connection to chassis from negative post of 1st smoothing PSU cap?
