Hello.
I want to connect 6 speakers to my laptop.
Now, I have 3 amps, 6 speakers, and my laptop.
The 6 speakers have different sounds each. ( That makes me confused....)
Even, I need loud sound.
How can I connect?
I'll give you the information about my speakers and amps.
amp1 : 50 + 50 W, 8ohm. (But, there are 4 sets of terminal)
amp2 : 30W, 8ohm. (only mono... stereo doesn't work)
amp3 : 250 + 250 W, 8ohm (there are 2 sets of terminal)
speaker1 (x1) : rms 60W, 8ohm
speakers2 (x2) : rms 75W, 8ohm
speakers3 (x3) :rms 100W, 8ohm total 6 speakers
I can I connect them to my laptop?
I'm waiting for your help~
How can I connect?
All of them are just full range passive speaker drivers.
I'll connect the amp to the speaker directly.
That's not for a common hi-fi system.
Just for my project~
Help me~~
Help me~~
that's too confusing, connect them all to one amp3.
I'd make two sets for stereo, so each set has 2 speakers wired in parallel and 1 in series ~ 12ohm.
In that case(all to one amp3)... I'm wondering if I can have different six channel sound from each speaker.
What do you mean stereo doesn't work? Do both speaker outputs work when set to mono but not when the switch is set to stereo?
That works well for stereo. But, the one set of terminals was dead...........
So, only one sets of terminal(1 red, 1 black) can be working 🙂
if your laptop has multiple audio output jacks(front, rear, center/sub) then you can have 5 channel sound using all your amps.In that case(all to one amp3)... I'm wondering if I can have different six channel sound from each speaker.
I would use amp 1 with speakers 2
amp 3 with speakers 3 (Use two of them only)
get amp 2 fixed and get one more of speaker 1 or speaker 3
amp1 : 50 + 50 W, 8ohm with speakers2 (x2) : rms 75W, 8ohm
amp3 : 250 + 250 W, 8ohm with speakers3 (x2) :rms 100W, 8ohm
That leaves you with two different speakers and a mono amp2. You really need to sum a mono signal for this amp and use it for a sub or center channel.
I'm also curious... does amp1 have a A/B/A+B speaker switch?
Yes~ there are speaker A, B on/off buttons each(A button, B button)
And..
could you let me know how to connect that?
I know how to connect between amps and speakers.
But, I don't know between 3 amps and my laptop. My laptop has only one output jack...
And..
You can connect the remaining 2 speakers to the B outputs of amp1. To connect it all, you can just split the laptop output into 3, passively (wire and connectors) or actively (a distribution preamp).
Search for usb sound card with surround sound.Is there any device for that? mixer? soundcard? or any cable?
How abou this?
Creative Sound Blaster X-Fi Surround 5.1 Pro USB Sound Card powered by THX TruStudio Pro | Creative Labs Online Store
Also has a remote control.
- Full Range
- 6 speakers + my laptop
