6 channel stepped attenuator
This is how its should work.
As there are 2 raws with resitors on every deck.
So if you remove 4 decks,it can be run i balance mode.
Soldering a stepped ladder attenuator for a balanced amp is more difficult than soldering the amp itself, or at least as difficult. 😀
How many steps does it have? What's its brand? Is it an Elma?
Can you list the values of the resistors also?
200
402
750
1,1k
1,5k
2,0k
2,49k
3,16k
4,02k
4,99k
6,19k
7,87k
10k
16k
20k
25,5k
30,1k
39,2k
49,9k
56,2k
68,1k
75k
80,6k
84,5
90,9k
93,1k
95,3
97,6k
some are 6 peaces some 12 and 1 is 24.
I calculated this on the net,now I don´t know where
At the right price (for both)someone could take over this projekt..
