6 Channel LM3886
You might also consider a heat sink like this one found at http://www.apexjr.com/new.htm, just over halfway down the page. It's predrilled for a boatload of TO-3's, but, you could drill your own holes...
Tom.
6/8 channel LM3886 amp, with SMPS?
Im in need for a multichannel amp, 6 to 8 channels. I have decided to use the LM3886 chip, but still open for other ideas, as nothing have been purchased or written in stone yet. Im borrowing this old post from 2005.
Im thinking of ordering the chipamp.com pcb's, and use a SMPS to deliver the power.
Is it possible to use this SMPS from connex to power up 6 LM3886 channels in the same enclosure.
SMPS800RE
+-32V
Will there be any problems with hum, noise or other ground-related issues, and would the PS be able to deliver enough "juice"?
Am I right in assuming +-32V is a bit high for 4 ohm load?
Can another solution be to make 2 separate 4-channel amplifiers with this SMPS:
SMPS500R
+-24V
The same questions regarding hum and power does apply here too.
This is my first post on this forum, and i dont have alot of experience with electronics.
...........Am I right in assuming +-32V is a bit high for 4 ohm load?.........
You are right, but it is manageable if you take care to ensure your 4ohms speakers are of moderate reactance and you have normal domestic listening, where P average ~-20dB ref maximum output and you keep the chips cool.
NS have a graph showing the typical Heatsink required for operating temperatures at 150°C.
I always suggest you double the size of the sink for our typical use.
If for +-32Vdc (=64Vdc) and 4ohms with ambient temperature at the heatsink = 25°C, NS show 2C/W, then use 1C/W for each channel.
6 channels would require an enormous heatsink with a rating of 0.17C/W
