Hello I’m new here.
I’ll try to build a 6 cannel amp for my HTPC
I think about 80w8ohms per channel.
I need a print chart/component list
So what do you recommend?
Welcome to the world of DIY audio. You'll likely never go back to commercial products. There are lots of amp options. What is your skill level? Any electronics or metalworking experience? If one of those six channels is for your subwoofer, you might want to consider significantly more power for it.
There are a variety of chip amp kits available from several vendors. Until you bridge LM3886s you won't get to 80W, but you really won't notice the difference between 50 and 80W.
Rod Elliot has some good projects and provides good support. P3A is a nice amp 60-80W Power Amplifier, as is P101 although the output devices are a bit more expensive and harder to source.
Check the group buys section for some other PCB options.
For a less intense building experience, check out Aspen Amplifiers Hugh sells some very nice modules ready to bolt into your enclosure and hook up to your power transformer as well as modules for which you will need to supply a heat sink and power supply.
Hello thanks for the reply
What about?
1 X Apex B500
5 X Apex D14
Have Apex A place for his project?
Sincerely
svsommer
What about?
1 X Apex B500
5 X Apex D14
Sincerely
svsommer
I don't know that lots of people have built Apex amps like the others I mentioned, but the designs seem sound. Go for it, if you think it will suit. Does he sell boards? Build the smaller amps first and get the hang of it. Larger amps have more potential to make a mess if you've goofed something up.
Joined 2009
my 2c: You'll need to give some thought to the power supply if you go with a ClassAB amp - 6 channels at 80W is a fair demand which leads to large transformers and slow-start circuitry for powering it up.
If you want to learn about DIY audio then an HT amp gives you plenty of scope to do that. If you want to get a 6 channel amp up and running as soon as possible and still build it yourself then the chip amp suggestion is an excellent one.
I decided my HT amp would be fully home grown, my own power supply and amplifier design. It took at least a year before it was in service.
I'm a new guy doing pretty much the same thing, but as a nice office (computer) speaker setup. What have you come up with for doing the master volume control?
Hello Bigum
I say
I'm not a shark in this
I have time for it. I think!
I will not design the pcb. I will use a tested PCB
Hello SirNickity
If I understood your question
I use a Gigabyte GA-MA78GM-S2H
to master
I say
Hello SirNickity
to master
- 6 Channel Homebuilt amp
