New in box: 220VAC to 5VDC external linear power supply, ultra-low noise. Voltage is fine-tunable with a screw on the back side. Maximum current is 3.5A. Asking price: € 50, shipping from The Netherlands.
Outputs:
Of Chinese make but with high quality components:
Dimensions (b x l x h): 102 x 150 x 60 mm
Weight: 1,1 kg
Also available in 12V.
Outputs:
- 1x 5,5 x 2,1 mm jack plug
- 2x USB-A (note: 5V only)
- 4x high speed diodes
- Philips filter capacitors primary side
- Panasonic FC and Siemens filter capacitors secondary side
- includes EMI filter
Weight: 1,1 kg
